Which Graphics card to use with HCPC and Powerstrip?
Discussion in 'Desktop & Laptop Computers Forum' started by Newboybee, Apr 1, 2003.
  1. Newboybee
    Newboybee
    Am currently looking to source a graphics card to build my HCPC to use with a Sanyo Z1 projector.
    Any advice on which is best card to buy, i would want to use it with Powerstrip.
    Also where could i purchase said graphics card?
    best regards
    NBB
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,937
    Manchester, England
    +81
  3. Newboybee
    Newboybee
    Cheers..games are not an issue at all.....any other opinions on this card......or any other suggestions?
    best regards NBB
  4. Underscore
    Underscore
    That card looks to have a fan (assuming the picture is of the correct card) I've bought the Sapphire 9000 (non-Pro) Atlantis that you can find on this page. Not hooked it up to the Z1 yet as the cable has only just arrived but it is passively cooled, has VGA, DVI and S-video out and seems to do the job. Of course, say that will ensure that I have all sorts of problems getting it working with the PJ...
    HTH,
    _
  5. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,937
    Manchester, England
    +81
    Yeah the picture is just a generic one, AFAIK the card has no fan either.
    Either way a non-pro version of a radeon 9000 seems to be the consensus for high quality, quiet, cheap graphics card.
    Owain
  6. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Would also recommend a Radeon 9000 - no fan, brilliant performance with dvd playback, takes custom resolutions no prob.
    All the best,
    Sean G.
  7. MrRails
    MrRails
    Hi there
    Could someone give me some advice on how it handles games ? Although my main priority is tv/pvr can the 9000 handle games ok. I'd like to be able to use this machine as an ever so often games machine to play things like "Colin Mcrae 2" networked.
    Do you know what the equivalent GeForce is just so I can get an idea of comparison as I come from the Geforce world.
    Cheers for any advice
    MrR
  8. Desmo
    Desmo
    Jan 4, 2001
    13,573
    Braintree, Essex.
    +4,940
    Can someone clarify a question I have about these cards? I need to have 2 different resolutions on two different monitors. I need 1280 x 1024 on a TFT via the DVI or VGA and then 800 x 600 on a TV via the S-Video. I'm 99% sure this isn't a problem for these cards.
    But I don't just want video mirroring. Can the desktop be spread across the two screens or treat the two screens as separate monitors/desktops. I basically want to have control software (Cinemar Mainlobby) only showing on the TFT, whilst video playback software (ZP, Showshifter, etc) is only showing on the TV.
  9. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,937
    Manchester, England
    +81
    I've got a 9000pro in my desktop (I'm sure the non-pro would be the same) and it handles what you require perfectly. I have a two-monitor setup (2x CRTs) one at 1280x1024 and the other at 1152x864, this is no problem. The desktop is spread across the two, not mirrored.
    Before I got my second monitor I had a TV connected via svid and this worked fine too.
    HTH
    Owain
  10. Desmo
    Desmo
    Jan 4, 2001
    13,573
    Braintree, Essex.
    +4,940
    Strange, I didn't get a notification email about your reply.
    Anyway, pretty much answers my questions. Cheers Owain.
  11. jmack
    jmack
    hi i want the excact opporsite to you i want it mirrored but have it
    spread accross 2 monitors 1 tft monitor and a plasma ?
    can you tell me how too mirrow it ?
    i`m using a radeon 9700 and windows xp
  12. feet14
    feet14
    Mar 13, 2002
    88
    UK, West Midlands
    My Sapphire R9000 handles games well enough for most people - GTA3@1024*768*32 with no jerkiness and all the graphics settings at the max. Picture quality is great whatever the task. It should be faster than a Geforce4Mx though slower than a Ti.
  13. MrRails
    MrRails
    Just the info I needed. Thanks for your input
