which gpu for gaming?
Discussion in 'Computer Components' started by 05ryan, Sep 10, 2012.
  1. 05ryan
    05ryan
    Aug 5, 2011
    104
    hi guys, im a bit stuck as too which graphics card to buy for my system
    i5 2500k
    8gb ddr3
    asus p8z68vprogen3.
    120gb ssd
    2tb hdd
    650w psu
    I have a maximum budget of around £150 and have looked at these cards so far and would like to be able to play games at 1080p like bf3 and fifa:
    any other ideas welcome! cheers:)
    XFX HD 6870 900MHz 1GB GDDR5 Dual DVI Dual Mini.. | Ebuyer.com
    XFX HD 6850 1GB DDR5 VGA DVI HDMI PCI-E Graphics Card | Ebuyer.com
    PowerColor HD 6870 1GB GDDR5 Dual DVI HDMI Dual Mini.. | Ebuyer.com
    Sapphire HD 7850 OC Edition 1GB GDDR5 Dual DVI HDMI.. | Ebuyer.com
    EVGA 1GB GeForce GTX 560 Ti SuperClocked NVIDIA Graphics Card - 01G-P3-1563-KR - Scan.co.uk
  2. dacads
    dacads
    Jul 24, 2009
    1,379
    Peterborough
    +155
    I would go with a 7850 mate :smashin:
  3. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,731
    Norfolk
    +2,492
    Which 650W PSU is that?
  4. 05ryan
    05ryan
    Aug 5, 2011
    104
    Corsair hx650w modular
  5. LJx
    LJx
    May 29, 2009
    3,262
    uk
    +446
    Don't buy that 7850!! It is the 1GB model for £160 - you can buy the 2GB model for less than that. You should still definitly go for a 7850 though just not at that price
    1GB model £132 MSI Radeon HD 7850 OC 1024MB GDDR5 PCI-Express Graphics Card - Aria PC
    There are plenty of 2GB models under £160 have at look at Aria, Overclockers maybe even amazon
  6. 05ryan
    05ryan
    Aug 5, 2011
    104
  7. Jamezinho
    Jamezinho
    Apr 12, 2007
    10,646
    Ipswich, Suffolk
    +3,353
    As an owner of a Sapphire 7850 I can highly recommend this card. Make sure you get a 2gb version and try to get one with dual cooling (such as a Sapphire, MSI, Asus, XFX).
    Awesome card, cool and quiet with huge overclocking potential. Definitely the best option in this price range.
  8. 05ryan
    05ryan
    Aug 5, 2011
    104
  9. LJx
    LJx
    May 29, 2009
    3,262
    uk
    +446
    I would pick the MSI Twin Frozr for sure out of all the ones mentioned, they are pretty well regarded and that is a decent price for one of those
  10. Jamezinho
    Jamezinho
    Apr 12, 2007
    10,646
    Ipswich, Suffolk
    +3,353
    Any of the non-reference models with the dual cooling will serve you well. I'm really pleased with my Sapphire 7850. Overclocked the hell out of it and still runs cool and quiet so definitely one to consider.
    I wouldn't bother with the OC editions if they carry a price premium, otherwise go for it.
