Question Which gaming headset do you recommend and wired or wireless?
Discussion in 'PC Gaming & Rigs' started by tony kop77, Jul 13, 2015.
  1. tony kop77
    tony kop77
    Sep 27, 2002
    6,316
    103
    Northamptonshire
    +305
    I currently have sennheiser pc360 and astro mix amp but my mic no longer works so only using 1 audio cable which prevents it being as loud as it once was though get sound via both cans.
    Anyway looking to replace them and see astro a40 headset with mix amp for £130 while the a40 are wireless and £140 though not sure if they come with the mix amp as it's illustrated in photos but doesn't state it on argos website.
    What headset do you guys recommend, it has to work on all formats and do you lose quality or lag if using wireless?
    Wired mix amp
    http://www.argos.co.uk/static/Product/partNumber/1115413.htm
    Wireless, mix amp illustrated not sure comes with it though
    http://www.argos.co.uk/static/Produ...Product/partNumber/1394973.htm&referrer=COJUN
    I want it to work with PC, xbox one, PS4 and multimedia devices.
