Which Freeview Recorder? Help?
Discussion in 'Blu-ray & DVD Players & Recorders' started by rbrocklesby, Sep 21, 2007.
  1. rbrocklesby
    rbrocklesby
    Sep 16, 2007
    5
    Howdy all,
    I'm really confused and would like some advice (don't we all) :lease:
    I want it to be have the following:
    HDMI uscaling
    HDD 160 or 250
    Be able to record 2 channels at same time (preferably both digital).
    Pause/rewind Live TV.
    Not particularly bothered about DVD recorder.
    Any suggestions [email protected]
    Just in case there isn't such a thing can you use a SKY+ box to do this instead? (with no subscription tp SKY)
    Thx in advance
    Ronnie
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,724
    Somewhere in South Yorkshire
    +6,296
    Let's start you off with:
    1: Freeview and Free-to-air Satellite are not the same thing. One comes from ground-based transmitters and is received using an aerial; and the other comes from Satellites and is receved using a dish. Equipment used for reception of one will not work for reception of the other and vice versa.
    2: You do not need HDMI Upscaling.
    3: If you want to record two digital programmes at the same time, then you need either two single-tuner boxes, or a twin-tuner box. DVD recorders do not have twin tuners. None of them. Twin Tuner boxes are PVRs.
    4: The only regular PVR for satellite is Sky+. You can use this without a programm subscription, but, last time I looked, you had to pay a tenner a month for it to work. There is a separate forum for Sky & Sky+ matters.
    5: There are a number of makes/models of twin-tuner PVR for Freeview (terrestrial, from an aerial). Ask about those in our PVRs forum.
    6: You say "Not particularly bothered about DVD recorder.". Just an observation that it's a bit odd you should choose to ask this in the DVD Recorders forum, then. See you over at PVRs or Sky/Sky+ I guess.
  3. rbrocklesby
    rbrocklesby
    Sep 16, 2007
    5
    Thx Nigel.
    Apologies for my lack of knowledge,
    Don't even kno what a PVR is - cheers for pointing me in the right direction
    Ronnie
