Which Freeview Box?
Discussion in 'Freeview & YouView' started by Henry, Aug 14, 2005.
  1. Henry
    Henry
    Aug 9, 2000
    2,162
    Hull
    +52
    My sister's after a freeview box and I wondered if anyone had any recommendations as to which one to choose? She'd spend up to about £150.
    Cheers!!! :smashin:
  2. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    East Yorkshire, England
    +171
  3. mike7
    mike7
    Jan 3, 2005
    4,604
    Norwich
    +503
    It'll be a problem to spend that much. Prices range from about £35 to just under a hundred. Not a great deal of difference in the quality. Why not lash out £35 on one from Tesco and see how it goes.
  4. dogtanian38
    dogtanian38
    Oct 18, 2004
    60
    Agreed.
    if your sister does not really know that much, then why spend any more than necessary. If reception appears to be a problem, and assuming you yourself have a decent one that yields better results on the same aerial lead, then take it back and spend more money. My philips dtr500 is connected via svhs, but the g/f, sister and half my male friends can't identify the difference when the tv is incorrectly set to AV2 (composite) with bad colours and jaggies rather than AV2-S, I get the feeling most people, possibly including your sister are the same.
  5. Henry
    Henry
    Aug 9, 2000
    2,162
    Hull
    +52
    I believe that some of them have Hard Drives in to record stuff too. Any of them worth looking at?
  6. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    They are usually called PVR's. Most have two tuners so that you can record and watch something different at the same time. In fact most of them allow you to record two things at the same time. See here
    If she is spending that sort of money she is closer to what these cost than a simple STB.
    Richard
    Also look at the PVR forum just above this one.
  7. Dr Diversity
    Dr Diversity
    It all depends on how much space you have for your sister's box. If you go the seperates route then upgrading is cheaper and simpler. Or else go for the combined box
  8. Henry
    Henry
    Aug 9, 2000
    2,162
    Hull
    +52
    That's an excellent chart. I've passed it onto her to have a look at. Cheers! :smashin:
  9. Henry
    Henry
    Aug 9, 2000
    2,162
    Hull
    +52
    I'd rather not discuss my sister's box thanks! :devil:
    Size doesn't matter. Must cut out the innuendos. She's not worried about how many boxes she ends up with. If you're suggesting separates, what would you recommend?
  10. bradavon78
    bradavon78
    May 31, 2004
    3,192
    South West, England
    +133
    Fat lot of good if you want TopupTV. For the kind of money Sony charge I'd demand a card slot.
  11. Rasczak
    Rasczak
    Apr 3, 2002
    21,218
    Argyll
    +2,267
    There is a massive difference in performance between the units. Speed of menus, ability to 'store' EPG data, handling of text/inactive services for example are noticeably better on performance units such as the Sony. Picture quality and audio also are noticeably better on high value units: comparing my Topfield 5800 with my Sony D800U for example the latter is definetly the better.
    If you want PVR functionality then obviously the Sony isn't for you - but to suggest you're not getting a significant benefit from such a high quality box is mad!
  12. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    There are some cheap new Pace Twins on Ebay occasionally
