Which freeview box for my tv?
Discussion in 'Freeview & YouView' started by BandofBrothers, Oct 30, 2005.
  1. BandofBrothers
    BandofBrothers
    Oct 25, 2005
    3,071
    +174
    I have ordered a Samsung SP50L6HX TV which will be here in a few weeks time.
    Now, what freeview box would u all recommend?
    (Im currently using a cheapo £20 Sagem one from currys via scart)
    Would this still be okay, even for my new 50" hdtv?
  2. mjcairney
    mjcairney
    Oct 26, 2003
    7,319
    2
    137
    Airdrie, Scotland
    +1,105
    If it's a straight Freeview box (rather than PVR) you're after, then I would definitely recommend the Sony VTX-D800U.
    If, however, you're after a PVR, then I would leave that recommendation to someone better qualified than me.
    Best of luck with your choice.
    Cheers,
    Martin.
  3. BandofBrothers
    BandofBrothers
    Oct 25, 2005
    3,071
    +174
    The sony is also just a normal "scart" box?
    If it is, surely I wouldn't notice any difference over my existing one?
  4. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Did you know that the VTX800U is basically the tuner from Sony IDTVs in a different box?
  5. mjcairney
    mjcairney
    Oct 26, 2003
    7,319
    2
    137
    Airdrie, Scotland
    +1,105
    I can't believe that a £20 box can be as good as a Sony one which costs five times as much, albeit you can buy the Sony now for £79ish, I believe from www.amazon.co.uk
    Cheers,
    Martin.
  6. Geofbob
    Geofbob
    Jun 15, 2005
    2,293
    83
    +304
    Assuming there's no connection problem, surely, you should try your current box with your new TV, and see how it works, before buying anything else. If it ain't broke etc etc.
  7. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    Agree - try it first and if its OK stick with it. I have three HDD PVR's but still use my Sagem and Grundig STB's.
  8. BandofBrothers
    BandofBrothers
    Oct 25, 2005
    3,071
    +174
    okay thanks guys:)
    I will keep my existing Freeview box and see how it looks when my telly arrives
    Thx again!! :thumbsup: :) :)
