Darbyweb
There seems to be loads of models available, most around the 99 mark - which is going to be best to go with my Pioneer Plasma.
Dean.
Dean.
Originally posted by Fernsehman
There are lots of Plasma screens which are incompatible with Sky and Freeview receivers so be sure to see it all working before you part with your cash.
Fman
Exactly how many plasma's are not compatible with composite or RGB signals???? And how many wont work with an RGB>VGA converter box?????Originally posted by Fernsehman
Fman
Originally posted by cybersoga
Don't get the Panasonic, it has terrible sound quality when you hook it up either with the built in RCA sockets or by taking the sound from the scart.
I just found out that the netgem has component output via scart as well as RGB, S-Video and Composite!
Originally posted by Darbyweb
Ok i know which ones to look at - do they all have 2 scarts ??
I want to cascade through the Freeview box.
Dean.
