Which freeview box? Again!
Discussion in 'Freeview & YouView' started by bigrich, Oct 30, 2003.
  1. bigrich
    bigrich
    Which box is the best, needs component output. Any help appreciated. I was thinking the netgem i player, are there any as good as this but cheaper. Anyone know the cheapest place to buy the netgem or any box you reccomend.
    Thanks.
  2. cerebros
    cerebros
    Dec 27, 2002
    1,190
    38
    Leicester
    +11
    If you want component, I-player is currently only way to go.
  3. phenom2003
    phenom2003
