Divide by zero
- Joined
- Dec 28, 2006
- Messages
- 1,608
- Reaction score
- 93
- Points
- 343
We are looking at getting a new Freesat HD Recording box for Mum. She has an old sky disk with 1 connection and we wont be able to run a new cable in as it would require work on her newly refurbished living room.
Given that we only have the 1 cable, is it possible to do this?
We would be happy if you could only watch and record one channel at a time, but as long as there is a way we can actually do both without having to swap the cable over each time or anything daft.
I've had a look at some other posts and can't work it out. I have read you can't split the cable which is fine... but not if it will work with 1 cable only.
The specific box Mum was looking at was the Panasonic DMR-HW120EBK .
Any help would be greatly appreciated.
DbZ
DbZ
