Which Formats do you use?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by dmckillop, Apr 25, 2002.
  1. dmckillop
    dmckillop
    I've just finished editing a couple of films with Adobe Premiere 6. They're currently taking up about 6Gb of space on my hard disk.
    I was thinking of saving a VCD copy for TV viewing and a Divx 4/5 to keep on the PC. The Divx being the better quality copy.
    What formats do you guys use? I don't want to delete these clips until I get the best quality copy I can get.
    I'm thinking of getting a DVD burner when they come down a bit in price. Then this shouldn't be an issue anymore :)
  2. Floandal
    Floandal
    The most economical way to keep "raw footage" is on DV tape.
    You will be disappointed with VCD - (Mpeg 1) as it will not display well on a full size TV.
    Send your edited footage back to DV tape, until you buy your DVD burner, --- "You know it makes sense" !
    Alan.
  3. dmckillop
    dmckillop
    It just means I have to get a DV in convertor for my camera. It's a Sony TRV-120.
    Or is it a software thing?
  4. Floandal
    Floandal
    See the post above that I just made to Gazza, - "Panasonic DS 27"
    Alan.
