C
chaldon
I've just purchased my first DVD recorder - Panasonic DMRES10 - after good
reviews and recommendations.
Mostly want it for archiving movies from my Fusion FVRT200 HD recorder.
Well it works, but I'm horrified to find that on DVD-R disks (all I've got
at present) the recordings are always in 4:3 ratio. Manual says it can only record to DVD-RAM in 16:9. Is this normal, and if so why?
I thought DVD-RAM was only useable in (selected) recorders, and remains read-write, so its hardly a medium for long term archiving or portability.
Should I return the recorder and buy something else? (What?)
Or should I stock up on DVD-RAM disks (and why do some come in a cartridge - are DVD-RAM disks more fragile?)
