Which floorstanding fronts?
hebawom
I have a budget of about £150 and am looking to replace my current speakers as part of a home cinema set-up.
I was thinking about the Mission M33's?
Can anyone recommend these, or not?
Bassbin
Depends what your other speakers/sub are and what sort of finish you want. £150 should buy you a nice used pair of floor standers or a very basic brand new set.
hebawom
Well, I'm looking to upgrade piece by piece, and since one of my front speakers got damaged, I'll start there. Have you heard the missions?
Kazman
£150? get standmounts, you will get a much better sound for your money :)
thekingbeyond
I have owned a pair of m34`s for about a year, and had a demo of the m33`s and thought they sounded good, but i liked the deeper bass of the m34`s.The m33`s are good value for money and they are good looking speakers as well.
