Which Floor Stands please????????
Discussion in 'Home Cinema Speakers' started by warmar, Jul 13, 2005.
  1. warmar
    warmar
    :lease: Please can you offer some ideas for floorstanding speakers for an audio set up using
    Cambridge Audio 640a
    Cambridge Audio 640c
    Cambridge Audio dab300
    Many thanks
  2. milpai
    milpai
    Mar 30, 2005
    23
    I use the Quad 21L with NAD. I luv them for their neutral sound. They may be a bit polite for Rock/Pop/Hip-Hop music. The others you can audition are Dali Evidence series, Audio Physic Yara, Meadowlark Krestels, Totem Arro or Sttaf. Different price ranges, but 1 of them should appeal to you - like the Quad 21Ls for me :D
  3. chris
    chris
    Nov 20, 2000
    1,216
    romney marsh, kent, uk
    +28
    PMC GB1's.
    Brilliant little floor standers, that sound good and go deep.
    And being small they dont get in the way or take up to much room, plus they are front proted so can go close to the wall ( evern further out the way ).
    I'm not sure what your gear sounds like, but my GB1's sound brilliant on the end of my Arcam A90.
  4. stevos
    stevos
    May 16, 2004
    5,979
    +541
    What's your budget and how large is the room?
  5. warmar
    warmar
    the room is 10x11 feet,budget is whatever within reason.i guess there is no point on spending loads as the kit is only budget+ maybe £300-500?
    warmar
  6. little fighter
    little fighter
    Try the rega r3's, they cost about £450, and sound like they should cost double.
  7. Dankeech
    Dankeech
    Feb 1, 2005
    3,592
    Stevenage, Herts
    +297
    Try auditioning Acoustic Energy Aegis Evo 3's.
    Haven't heard the other speakers mentioned in the thread, but the quality on these are stunning for the price.
    Cheapest price is http://www.sevenoakssoundandvision.co.uk/ of all places approx £230.
    What Hifi advise best speakers under £500.
    (for £230 there's certainly no complaints and I was surprised it was sevenoaks who were the lowest price).
    Couple this with some QED Silver anniversary with Airloc connectors for a sound far past the price range.
    Check out the others in the thread too; I have no experience of them so they may be even better sound in the price range
  8. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    +25
    If you really want floostanders...
    AE Evo3
    KEF iQ5
    Focal 714s
