Which Firewire card?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by balders, Jan 25, 2002.
  1. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    Can anyone recommend a good, cheap Firewire card, together with a supplier? I only want the card, not the
  2. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    OOPS, accidentally hit the wrong key...
    Can anyone recommend a good, cheap Firewire card, together with a supplier? I only want the card, not a software/ card bundle.
    Thanks,
    Nigel.
  3. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,605
    7
    167
    Birmingham, UK
    +10,474
    Please edit your posts if you make a mistake. Rather than posting again.
    www.ukdigital.co.uk
    Card and cable for £30 and work fine with my Sony TRV30 and Win 2K PC.
  4. laurel
    laurel
    Try CCL Computers
    £23.10 inc. Cable.
    Mine works a treat.
    Laurel
  5. DigiStuff
    DigiStuff
    Jan 22, 2002
    151
    When getting just a card, I would strongly recommend you get one with the TI chipset and NOT the Lucent or Via chipsets. TI works better with more DV Camcorders!!
    www.datavision.co.uk have one with 3 external ports and 1 internal with the dual TI chipset. Best OHCI 1394 card you can buy! It's called Naked DV or look at the DV Capture with cable and basic software.
    Regards
    Mark
  6. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    Thanks, folks.
    I'll check out your recommendations.
    Nigel.
