Which Firewire Cable?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kevo, Dec 15, 2003.
  1. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +149
    I'll be trasferrring from Digital 8 camcorder to Panasonic DMR-E100 DVD recorder using the iLink/Firewire socket.
    In my CPC catalogue they do various 4 way Firewire cables (same length) at different prices....
    £1.39
    £3.60
    £3.38 (Transparent insulation and bradided cable)
    £13.30 (99.99% POCC conductors, Advanced cable shielding, EMI suppressors :confused: )
    Basically, does it make any difference what quality cable you use when transferring digital data?
    What am I likely to gain with the most expensive cable (obviously not pic quality!) or lose with a cheaper cable?
    Cheers.
