Which entry level projector should I get?
maxaud
I'm looking at getting an entry level projector for gaming on my PS3 in a theater room in my house.
I currently use an Optoma HD65 but it's my brothers and he needs it back.
I've got a bunch of Walmart gift cards that I have to sue so preferably something available from Walmart.
It needs to support an HD 1080p or 720p signal from my Playstation 3 and look good.
I've been searching and came up with the following so far:
Optoma HD66 - A step up from my current setup and a generally rounded projector.
Acer X1320WH - seems to have some better specs than the Optoma, different aspect ratio, and is a bit cheaper.
BenQ MW516 - higher contrast ratio, but I haven't heard much on BenQ before.
Here are all four projectors in comparison with the HD65 in the lineup as well.
Compare Projectors
What are your thoughts? suggestions? pros? cons?
Thanks!
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
