Which electric screen?
Discussion in 'Projectors, Screens & Video Processors' started by petrolhead, Nov 30, 2003.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,484
    71
    Newcastle
    +82
    I have been using a Draper Luma 8' Manual Pull Down Screen for a year and to be honest I would best describe it a adequate.
    I am now thinking about an electric 8' screen.
    I sit 12' from it and need the extra black at the top, so I think 8' is ideal butr again I am willing to be told different :lesson:
    I can not afford a Stewart before anyone suggets :). I have a budget of £800-£1000
    I run an Epson TW100 if that helps which siits about 13-14' away
    There seems to be so many available:
    DaLite
    VuTec
    Owl
    Projecta
    Ellie
    The important thing is that it must be wrinkle free. I have seen a couple of owls and althought not the thickest material the only problem I have seen is slight curling at the edges (The black area either side)
    The Projecta does a Cinelpro with a Matt White M fabric which is 1mm thick which seems very thich and would therefore not wrinkle??
    So thats my delema and I would appreciate any help/advice (Gordon?) or anyone :)
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Slightly impartial, being Vutec Tech Support for the UK, hopefully backed by those like Gordon. We have a screen fabric called VuFlex Pro that will hang flat due to it's internal structure, so you don't get any curled edges or wrinkles on the screen. I think it will be just past the top end of your budget though. It's a 1.3 gain fabric also.
    Richard Wilson
    Technical Support
    Marata Vision (UK distributors for Vutec)
  3. SSB
    SSB
    Jun 16, 2003
    1,510
    63
    North Cumbria
    +173
    From what I've heard, projecta screens are a cheap option, but not of the highest quality. I can't imagine them being any better than the Draper you have.
    As you've seen on another thread, I have had a duff pull down screen from Da-Lite, but I've been assured that it's a freak occurrence. So, I wouldn't discount them prematurely. I should get my replacement in the next fortnight, so I'll post back ... hopefully to extoll the virtues of the replacement. On the positive side, I can't fault the customer service at www.audiovisual.co.uk, which has been the saving grace really.
  4. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    DRH do a 7.5ft one for £442.
    I've got a 6ft and it seems pretty good to me.
    DRH Screens
