Which DVR to include in a new HC setup?
Discussion in 'Blu-ray & DVD Players & Recorders' started by lapman22, Sep 7, 2004.
  1. lapman22
    lapman22
    I'm about to spend a great deal on a new home cinema setup. That will include a Pioneer 504HDE set , Pioneer VX5Ai AMP and a Pioneer 868AVi DVD Player. Speakers and Sky+ will (almost) complete the package.
    As I own a HTPC with a Sony DVD Recorder , which will also be connected , I thought of investing the remaining budget (upto 350) on a DVR set for easy and quick recordings without the need to use the PC.
    Note the Pioneer badge all over my new kit , Is it worth going with a Pioneer DVR like the 320? Would the fact that Sky+ has a HDD "save" me from going to the DVR+HDD machines?
    Cheers,
    Lapman.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,201
    Argyll
    +2,258
    No! Sky+ HDD allows timeshifting and, whilst a HDD/DVDR combo also allows that, it's primary purpose is to provide an space larger than the DVDR to enable editting and dubbing to highly compatible disks with no wasted space.
    A HDD/DVDR combo such as the Panasonic E85/95/500, the Toshiba RDXS32 or the Pioneer 420/520/720 is the ideal companion for Sky+.
    Before you buy ask yourself if you want/need iLink - a connection for a digital camcorder. If not, and you want a standalone, look at the cheaper Pioneer 220. If you want a Pioneer HDD/DVDR without iLink look at the Pioneer 420. Pioneer models with iLink (and a price premium accordingly) are the Pioneer 320 (no HDD), Pioneer 520 and Pioneer 720.
  3. lapman22
    lapman22
    Thank you. I will look into the 520\720 than.
