Which DVI-D cable ? Single or Dual Link
Discussion in 'Cables & Switches' started by Ekko Star, Dec 27, 2004.
  1. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,616
    London
    +468
    Just got myself a new DVI enabled TFT monitor which I would like to hook via digital cable. These come in Single Link and Dual Link form and I am unsure as to which one to get ?!? Any ideas ?
  2. Akele
    Akele
  3. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,616
    London
    +468
    I am currently connected via VGA but suffer from ever so slight ghosting. The VGA cable is good quality.
    Is the image via DVI spot on and ghost free ?
  4. Akele
    Akele
    I did notice slightly less noise when changing from VGA to DVI but I don't think my monitor sufffered much from ghosting, even when using the VGA cable. When using the DVI cable most of the monitor allignment settings (h-position, geometry, ect) are unavailable; thus it is almost impossible to have the monitor set up wrongly. I do still notice a bit of streaking on my monitor when playing fast moving games, but that is because it has a response rate of 25ns, and no matter what the cable it can't be avoided.
    You probably won't notice a massive difference between VGA and DVI (I didn't) but if your monitor is suffering from a bit of ghosting, a DVI cable may be the way to go.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,700
    The Borders
    +3,071
    Ekko Star
    Unless your Source and Display are able to use the Dual Link (up to 2048x1536) a Single Link (up to 1920x1080) will suffice.
    Best regards
    Joe
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Joe beat me to it, but I've just come across this definition while researching something, which may help:
  7. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,616
    London
    +468
    Thanks guys for all the help. In the meantime I did find a good site that explains all the differences as well.
    http://www.datapro.net/techinfo/dvi_info.html.
    I've ended up with a DVI-D dual link, there was only a few quid in it over the single.
    Over analogue VGA the difference in DVI is ever ever ever so slight. The ghosting has gone but it's not as pin sharp as I was expecting it. I guess it's TFT imaging. It's not as nearly good as the outgoing CRT via VGA ~ BNC cable.
    Still, I can live with the Iiyama considering it's relieved my desktop of 21Kg ! Thanks once again.
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,700
    The Borders
    +3,071
    Hello Ekko Star
    I'm often amazed at friends who seem to expect all 'Flat Screen' LCD monitors are the same - one recently asked for recommendations for a decent PC monitor (used for long periods on a daily basis) and decided my recommended unit (near 1K) was way too much and plumped for a £350 model and then invited me round to try and 'fix' the picture as it was 'all blurry'. :)
    Best regards
    Joe
  9. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,616
    London
    +468
    Hi Joe, mine was a bit less than that :blush: An Iiyama Prolite 435s it is, was meant to be one of the best in it's peer group.
    TBH I've not seen a TFT screen that I have really been satisfied with but needs must, the desktop needed space.
