which dvd ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Zack, Jan 24, 2001.
  1. Zack
    Zack
    Have got about £250 to spend on a dvd player
    which can play R1 & R2 which one should i go for?
  2. RMCF
    RMCF
    Aug 24, 2000
    7,571
    +785
    I'd go for the Toshiba SD100E. You can get it multi-region from plenty of shops for around £199-£219. Check out the advertisers in the mags. It has unrivalled picture and sound quality.
  3. Greyhound
    Greyhound
    Aug 23, 2000
    64
    Although a good player (I was considering it myself), at the moment the Tosh only has automatic region switching. This means that they can't play R1 RCE discs without using work arounds.
  4. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    You could try the Hitachi 505 from dixons with the multiregion software from my site.
    I have one its great.
  5. DaBuzz
    DaBuzz
    Techtronics will have an RCE fix for the Toshiba's soon, so wait around. The Toshiba 100E beats my £400 Pioneer 626D for picture and sound quality. My Advice is WAIT!
