Which DVD software do you use?
Discussion in 'Desktop & Laptop Computers Forum' started by mike.hutch, Apr 3, 2003.
  1. mike.hutch
    mike.hutch
    Feb 28, 2001
    1,005
    48
    Bristol
    +27
    I'm looking at windvd or powerdvd, which is the best? or any others I should look at?
    Thanks.
    Mike
  2. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,796
    41
    Kent
    +18
    I'm REALLY new to this but TheaterTek seem to be miles better than anything else and is the overwhelming software of choice for HTPC.
    www.theatertek.com
    Hope this helps,
    Mark.
  3. mike.hutch
    mike.hutch
    Feb 28, 2001
    1,005
    48
    Bristol
    +27
    I'll give it a look, cheers.
  4. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Only thing with Theatertek is that it does no decoding, but as long as you're feeding the audio to an av amp for processing and amplification, you'll be OK. I'm using the PC to decode, so Theatertek isn't any good for me.
    I use WinDVD - some say that PowerDVD gives a "softer" image.
  5. mike.hutch
    mike.hutch
    Feb 28, 2001
    1,005
    48
    Bristol
    +27
    I'm not using the PC for audio processing, so I should be OK, I can't access www.theatertek.com at the moment, it just times out.
  6. dnrc
    dnrc
    Dec 23, 2002
    300
    16
    Near Norwich
    Power DVD mate, it's superb
  7. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    WinDVD has now caught up with PowerDVD in terms of functionality (particularly on the audio side) and picture quality is miles better - not so noticeable on a TV, but on an LCD/plasma the difference is like night & day.
    I was pretty shocked that there was so much difference when I recently switched from one to the other.
    MuFu.
  8. gingercat
    gingercat
    Nov 19, 2002
    489
    Lancashire, UK
    +26
    I've found WinDVD to produce a much more stable and clear picture than PowerDVD with my AE100, however, it does seem to thrash the processor a bit more (occasionally get a jerk). Then again, I'm only running a Thunderbird 800...
  9. Miron
    Miron
    Sep 26, 2002
    1,419
    Vienna, Austria
    +50
    WinDVD won the game with some smart marketing moves, but I'd still go for TheaterTek if you are into HTPC.
    And yes, I am using PowerDVD 3.0 but that's just me . . .
