Which dvd recorder for parents?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Matthew Attoe, Nov 19, 2003.
  1. Matthew Attoe
    Matthew Attoe
    Dec 8, 2001
    695
    Norwich
    +11
    hello,
    My parents want to buy a dvd recorder to go with their widey tv that they want to buy this weekend. They have a budget of around £300-£350. Looking for something with the following spec:
    RGB-in and RGB-out
    Use -RW or +RW (as well as -R or +R)
    Easy-to-use (parents, remember!)
    Must be able to record from built-in freeview in the TV.
    I look forward to you advice,
    Thank you,
    Matthew
  2. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    rdr gx3 nice bit of kit
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,235
    Warwick
    +2,278
    As far as I've seen most iDTVs will not output in RGB which would make the purchase of one with RGB input a bit of a waste of cash.
  4. Matthew Attoe
    Matthew Attoe
    Dec 8, 2001
    695
    Norwich
    +11
    Thanks for the replies, guys
    Jelly: any idea how much the sony is?
    Rasczak: Good point, hadn't thought of that.
    cheers
    Matthew
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,235
    Warwick
    +2,278
    The Sony would push the budget as it is around £380. Options for minus machines would include the JVC DMR1 or Toshiba DR1 (both around the £300 mark). But to be honest, mcuh as I hate to say it, if your not prepared to consider DVD-RAM/-R machines from Panasonic then your best option is probably a plus machine: you might as well opt for one of the sub-£200 cheapies (e.g. Mico, Grundig).
  6. Matthew Attoe
    Matthew Attoe
    Dec 8, 2001
    695
    Norwich
    +11
    Basically, they just want a machine that can use rewritable discs (they'll have a fit if they can only use each disc once) that they can lend to me :)
  7. Rasczak
    Rasczak
    Apr 3, 2002
    21,235
    Warwick
    +2,278
    Then one of the cheap plus machines from Grundig/Mico/Bush will do. You could spend a bit more and go for the Toshiba or JVC but if your parents are anything like mine they probably wouldn't appreciate the difference making them a bit of a waste of cash.
  8. primitive
    primitive
    Aug 22, 2003
    95
    I'd agree that a + machine is probably your best option (well I would wouldn't I!) but you might be better paying the extra £40 and get the Philips DVDR70. Many would question the quality of the Philips products but I would hazzard a guess that they will be better made than the Mico or Grundig.
  9. nwgarratt
    nwgarratt
    May 5, 2002
    26,436
    +2,870
    True, as my Sony IDTV is the same. I bought a freeview box and connected it to the recorder and record in RGB.
