Which DVD Recorder for NTL Box
Discussion in 'Cable TV & Virgin Media TV' started by JSW, Jan 22, 2004.
  1. JSW
    JSW
    Feb 21, 2002
    4,221
    Staffs
    +302
    From reading a few pages I gather my only choices are either Panasonic or Sony is that right ?
    Fancied the PIONEER DVR3100S but take it would have to record from the NTL box in composite :eek:
    Bry
  2. VFRSE7
    VFRSE7
    Dec 10, 2002
    11
    3
    It depends what NTL box you have. If it outputs RGB then you can use Philips DVD recorders to record and output in RGB. The +RW discs have encountered no problems being played back in a Toshiba, PS2 and a Mustek player. Cheap media too (£30 for 25 discs in PC world).
    My NTL box works well with the DVDR75. Don't believe the hype...
  3. JSW
    JSW
    Feb 21, 2002
    4,221
    Staffs
    +302
    Got a panny e60 from my local superfi today :)
  4. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    A number of people are suffering from incompatibility between panasonic machines and the ntl box. See related threads.
  5. JSW
    JSW
    Feb 21, 2002
    4,221
    Staffs
    +302
    In what way? the way that they connect there scarts?
    I have no probs with mine :D
  6. danny-p
    danny-p
    jsw,
    Do you have a pc?
    If so for under £100 you can buy an LG dvd burner which will read your pannys ram discs and allow you to edit them and burn to dvd-r..
    I own an E50 and thats what i'm doing @ the moment.
    All depends on your use though because some peeps just use them like VHS where they record something then wipe over it after they've watched it.
    P.S- (i'm going on the lines that the e60 only supports dvd-ram btw which isnt compatable with many stand alone dvd players)
    Danny
  7. JSW
    JSW
    Feb 21, 2002
    4,221
    Staffs
    +302
    hi,
    I have had a writer in my htpc for over 12 months ;) DVD Ram and DVD-R
    Bry
  8. danny-p
    danny-p
    Bry,
    didn't notice the "my HTPC" in your siggi (DOH!)
    Danny
  9. MikeHarrison
    MikeHarrison
    The Guide Plus+ system on the Philips DVDR80 can be sed to control NTL STBs - see www.redremote.co.uk/dvdr80.html for details.
    NTL 4001 STBs (blue remote) are not currently supported, but should be in a new firmware release due end of Jan.
