Which DVD Recorder for 16:9 recording from SKY & High DVD-+R Compatabilty??
Discussion in 'Blu-ray & DVD Players & Recorders' started by mdawkins, Jan 4, 2005.
  1. mdawkins
    mdawkins
    Aug 17, 2004
    130
    16
    Sydney
    I am looking at purchasing the Toshiba RD-XS32 as it has high reviews on this forum but I want to make sure it will meet my three main requirements which is being able to record in 16:9 from SKY to HDD then onto DVD-R, play the DVD-R's (and some DVD+R's) that I have of 'backed' up DVD movies, and can either be purchased as Multi-Region or 'hacked' in some way as I have a few Region 1, 3 & 4 discs.
    Any suggestions/recommendations would be appreciated before I spend what I consider a large sum of money on a DVD recorder.
    Martin
  2. Neville Street
    Neville Street
    Jul 11, 2004
    290
    +4
    I use the Tosh exactly as you describe, including playing back +R "back ups" made on my PC. Mine is multi-region and came from Richer Sounds last summer. £409 plus a 3 year guarantee.
  3. mdawkins
    mdawkins
    Aug 17, 2004
    130
    16
    Sydney
    Thanks for the reply,
    Looks like I will be ordering a Tosh soon, where is the best place to order a multi-region version?
    Martin.
