which dvd recorder can do this???
Discussion in 'Blu-ray & DVD Players & Recorders' started by moomin2005, Sep 22, 2005.
  1. moomin2005
    moomin2005
    Jun 9, 2005
    88
    hi guys i am wanting a decent not dear dvd recorder with great editing features, also i need to be able to record 9 full tapes of cartoon episodes to dvd and be able to seperate each episode and give each episode its own thumbnail before finalising the dvd, and need to be able to play it on any dvd player
    please please help i have a tight budget so cant afford a recorder with hdd
    many thannks
  2. moomin2005
    moomin2005
    Jun 9, 2005
    88
  3. sjw
    sjw
    Feb 19, 2003
    1,745
    63
    +182
    9 whole tapes onto 1 DVD?
  4. moomin2005
    moomin2005
    Jun 9, 2005
    88
    no lol cause i will only beable to get bout 4 eps per dvd
  5. laser
    laser
    Aug 1, 2004
    987
    Hartlepool
    +46
    How long are the episodes?
    If you want "great editing" features you should look at a DVD-r/-rw recorder NOT a DVD+r/+rw recorder.
    You should check out the latest Panasonic models as they record 4 hour LP mode with using 720x576 and not 320x??? pixels, thus you'll get better picture quality.
    Also consider Pioneer's latest DVD recorders as they will record to DVD-R (dual layer) which means you should get all the episodes onto one DVD. The new Pioneer DVD recorders also have 720x576 LP mode.
    http://www.leconcepts.com/dvd_home.htm
  6. moomin2005
    moomin2005
    Jun 9, 2005
    88
    i was going to get (cant afford much) the panny es10 but someone told me that if i record to dvd-r then i wont be able to seperate the episodes or do any editing
    is this true?
