Which DVD-R?
Discussion in 'Desktop & Laptop Computers Forum' started by SimonInd, Sep 16, 2004.
  1. SimonInd
    SimonInd
    May 9, 2001
    209
    London
    I've been playing around with burning TV programmes to DVD using Nero with my NEC-2510 and have so far had mixed results. Whilst the PC plays everything as intended, my Sony 725 DVD player has only flawlessly played one disc - a film burned at 1x speed with no menu or other features. I'm using grey Datawrite 8x discs, writing at 1x or 2x. Is there a more reliable brand of DVD-R that I should be using? something I'm missing or is it just that the Sony, being an old player, doesn't like DVD-Rs?
    Any advice appreciated
    Simon
  2. Kramer
    Kramer
    Probably.
    Have you tried DVD+R? Might be more acceptable to your Sony...
  3. mjn
    mjn
    May 24, 2001
    22,723
    Herts, England
    +10,867
    i've also had minimal success using the 725 to play dvd-r and dvd+r
  4. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Use Ritek G04
  5. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    www.blankdiscshop.co.uk always list compatible writers, plus search for info on the different dye compatibilty with standalon players. It's the dye that's important not the brand from what I've found, stick with a certain dye. I've found manufacturers change dye occasionally.
