Which DVD player to buy ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by alan_dublin_ie, Feb 26, 2001.
  1. alan_dublin_ie
    alan_dublin_ie
    Hi, Its probably been asked a 1000 times so my apologies. I was thining of getting the Sony Dav300 home theatre DVD Player. Its £599 here. I hear the subwoofer isn`t the best but its fine for a small-med sized room. Should I consider anything else ? I`ll probably get it chipped to play region 1.
    Will be using a Sony28FX65 if that matters.
