Which DVD Player / Recorder has got 5.1 output?
Discussion in 'Blu-ray & DVD Players & Recorders' started by jandrews73, May 27, 2005.
  1. jandrews73
    jandrews73
    I've currently got a pretty good 5.1 system set up, but it's built into the DVD player. Thing is that the player has broken and I don't want to go and buy a new system so I want a DVD player or recorder with 5.1 output. Looking to spend only up to about £250.
    Any suggestions?
  2. Geesus
    Geesus
    Dec 23, 2003
    2,338
    116
    +743
    The Pio 575 has 5.1 outputs and it a lot cheaper than your budget, but will outperform more expensive players, so might be worth a look.
