Toshiba SD360 plays them fine.
But it doesnt play high def Divx or XVid ... or even those pseudo hi-def 700mb per episode encodes.
So, if I have a movie 2:20/1, for example Lord of the Rings in DivX, roughly 16:7 will the Toshiba respect that, by playing in a wide 16:9 anamorphic mode with black bars on top, but still in proportion?
Also, on a standard 16:9 anamorphic DivX, will it will fill the screen up, play it progressive, in proportion? no squashing?![]()
I currently have it connected to a 4:3 tv and it plays widescreen with black bars at the top and bottom. It also has options where you can select aspect ratio / zoom etc.
So dont think it would be a problem for it to output to widescreen with black bars if it needs to. I havent had a chance to play with it on a widescreen yet.
