which dvd hdd do you guys recomend
Discussion in 'Blu-ray & DVD Players & Recorders' started by pianoman, May 4, 2005.
  1. pianoman
    pianoman
    hi folks i am in the process of buying a dvd recorder maybe with hdd ,i would be most grateful bfor your tips on which one to buy , i have around £300 to spend ,but there seem to be some good ones around ,lite on 5045 .toshiba etc
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,212
    Argyll
    +2,267
    Have a look at the 'Which DVD Recorder?' link in my signature. The best £300-odd HDD/DVDR combis at present are:
    - Panasonic EH50
    - Toshiba RDXS34
    - Sony RDR-XS510
    - Pioneer 720
    All have different pros and cons so which one is ideal for you depends on your requirements, i.e. do you need iLink? +/-/RAM compatibility, do you want to edit etc etc. Have a glance though the website article to point you in the right direction.
  3. pianoman
    pianoman
    thanks for the info i am swaying towards the toshiba rdxs34,as alot of people on this forum seem to like it
