Which DVD has denon link
Discussion in 'Blu-ray & DVD Players & Recorders' started by oz72, Apr 21, 2007.
  1. oz72
    oz72
    Jan 7, 2006
    447
    +23
    Hi got a KA1SE and have a denon 2900, just wondering what denon dvds have the denon link, would be looking for a gold to match amp. would i get much sound improvment if i upgraded to a player with denon link?
    thanks guys
  2. pils
    pils
    Jan 11, 2007
    104
    +5
    Of the current models, the 2930 and above have DenonLink 3.
  3. Jase
    Jase
    Mar 16, 2001
    10,934
    United Kingdom
    +3,247
    Has your KA1SE been updated with Denon Link S.E.? Should be a sticker on it to indicate that it has. The first KA1SE upgrades only had the original Denon Link which won't work with Denon Link S.E. or Denon Link3.
  4. oz72
    oz72
    Jan 7, 2006
    447
    +23
    Yep without going round the back im pretty sure its got a se label on the back, maybe Jules could confirm :)
  5. Jase
    Jase
    Mar 16, 2001
    10,934
    United Kingdom
    +3,247
    Sound quality wise I still think it's the best way to connect Denon components. Just sounds so clean, if that makes sense. I wouldn't change to a new player purely for Denon Link though. It would be part of the upgrade package of better video etc (if you're looking at the newer models like the 2930, 3930 etc).
    Gold might be a problem though. Only players with Denon Link that are gold are the older DVD-A11 and DVD-A1. The 3910 has Denon Link but isn't gold.
  6. Jules
    Jules
    Oct 11, 2000
    5,654
    137
    +1,162
    Hi :hiya: ,
    Yes the amp is Denon Link SE. It had the K upgrade first, then when back to Denon to get the SE link upgrade.
    It worked pefectly with my DVD-3930 set to 2nd Edition Link.
  7. oz72
    oz72
    Jan 7, 2006
    447
    +23
    Thanks everyone, jules is there much difference in your old A1 and the DVD-3930, am I right in saying the A1 wont play dvd audio mlp and SACD? What about picture quality?
  8. Jules
    Jules
    Oct 11, 2000
    5,654
    137
    +1,162
    The DVD-A1 will play DVD-Audio, but not SACD.
    It's my opinion that the DVD-A1 is better than the 3930 via component, and considerably better as an audio player.
    However, the 3930's picture quality is better than the A1 when upscaling over HDMI and the SACD playback is nice bonus.
    However, if you want the best CD replay possible from a 1 box machine, don't need HDMI and aren't bothered about SACD, then the DVD-A1 is better.
    The DVD-A1 is also much better built.
