Which DVD DISK
Discussion in 'Blu-ray & DVD Players & Recorders' started by vergil777, Mar 19, 2006.
  1. vergil777
    vergil777
    Mar 18, 2006
    113
    Which is the correct Dvd recording disk to use over and over again in a Dvd
    recorder, Is it the Dvd+RW or the DVD RAM DISK To erase and re: record
    over again on the same disk.
  2. Joed
    Joed
    Mar 20, 2006
    69
    Best disk imo to use is DVD RAM, you can use these around 100,000 times.
  3. bryfly
    bryfly
    Jan 15, 2006
    206
    28
    +51
    Who is doing the best deal on DVD Ram at the moment??
  4. ferris57
    ferris57
    Jan 18, 2003
    874
  5. Searcher2
    Searcher2
    Nov 18, 2003
    1,447
    48
    Blackburn
    +92
  6. dvdnoddy
    dvdnoddy
    Apr 19, 2005
    72
    +3
    I would agree that DVD-Ram disc's are best (as long as they are kept clean).
    However as long as Vergil777 is aware that they will only play in DVD-Ram devices.
  7. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    Many PC writers and DVD-ROM drives will now play DVD-RAM discs.
    The latest PC writers from Pioneer (DVR-110 and DVR-111) now also support RAM as do the NEC writers.
    http://svp.co.uk/products-list.php?pg=2
    Additionally the DVD PLAYERS from Panasonic, JVC and NAD also support playback of RAM discs. Have used ram discs recorded in both SP and LP in my Panasonic S27 player and playback is fine in either mode.
  8. visaria
    visaria
    Possibly a dumb question, but how much can be recorded on double sided DVD RAM? Is it simply twice as much as on a single side? It's just that I would rather record 2-3 hour films off TV using SP (or maybe even XP) rather than LP due to the difference in recording quality.
    Edit: Do double sided DVD-RW discs exist? Couldn't find any on the web...
  9. HMHB
    HMHB
    Nov 11, 2001
    27,390
    Nottinghamshire
    +6,256
    You would have to stop the recording and turn the disk over, so there's no real benefit with dual sided for films I don't think.
  10. visaria
    visaria
    I didn't know that, thought it just continued recording, thanks for that reply JohnG.
  11. visaria
    visaria
    Are there any single sided DVDs that have a larger capacity than 4.7gb?
