Which DVB-T card ?
Discussion in 'Desktop & Laptop Computers Forum' started by richjthorpe, Sep 14, 2005.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Hi all,
    I'll be looking to install Freeview cards in my PC but there are a few around and don't know which ones to pick.
    I'll be using something like MCE or Media Portal as the front end so I wont necessarily need the software that comes with it, just a decent quality picture.
    If I got a DVB-T card with an Infra Red header, but use MCE, would I still be able to the IR header to control the PC or will the IR header just be for the card's software ?
    By the way, does MCE still use it's own EPG or does it now pick it up from the signal ? Can Media Portal or any other media centre pick up the EPG from the signal ?
    Thanks,
    Richie.
  2. bigdic
    bigdic
    Dec 5, 2004
    83
    +3
    Most people reccomend Black Gold (they work with MCE) they are a good price. No remote with them so just use the MCE remote.
