Which DV editing package?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Chris Frost, Aug 11, 2001.
  1. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    I’m interested in using my PC to edit the footage from my DV camera. My computer is a 700Mhz Athlon.
    I know there are PC card/software packages to do this. Can anyone give advice on which are the best products to consider under £250?
    Thanks in anticipation.
    Regards
  2. Arthur.S
    Arthur.S
    Hi Chris,<br />this is something I was 'into' for quite a while. Managed to put together some fairly entertaining little movies of hols & stuff. I intend to upgrade to a DV myself soon. This'll need a completely different capture card & editing suite than my present package that I've been using with Hi8 material. <br />Ideally, apart from the capture software/hardware you'll need a 2nd large fast HDD to work on. (I use 2 especially for this) It'd be a mistake to try VE on your system disk. <br />When I started anyway (about 4 years ago) PC video editing was a very steep learning curve. Hopefully the newer software/hardware is more 'user friendly'. Anyway, sorry for waffling on. The best place to ask this question is the forum at <a href="http://www.computervideo.net" target="_blank">www.computervideo.net</a> Some very helpful/knowledgeable people there.<br />Also, buy the Computer Video mag & do lots of homework on the subject. It could save you a shed load of grief, believe me <img src="eek.gif" border="0">
  3. webster
    webster
    Hi Chris,
    Try <a href="http://www.digitalorigin.com" target="_blank">www.digitalorigin.com</a> (i think).
    they offer a free download of EditDV, which is basic but good. Failing that Adobe Premiere is great, but not £250!
    By the way, can you get me a service manual for my Philips 28PW662B/05? It's buggered.
    Simon
  4. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    Simon,<br />Thanks for the info. Sorry I can't help you in return with the TV manual, I work in a completely different division of Philips with no access to such things.
    You could try some of the smaller independant TV retailers. Those with a Philips service account will be able to get a manual for you.
    Regards
  5. CarlB
    CarlB
    Jan 8, 2001
    1,339
    Cambridgeshire
    +254
    I've been using Adobe Premiere for a few years now and would highly recommend it, although it is outside your price range. See if you can get a copy second-hand, because then you will be able to upgrade the software for a more reasonable price from that point on.
    It's very easy to learn and extremely powerful, it'll ensure you don't have to switch to a new package in future when your ideas begin to outgrow a more basic package.
  6. dougbryson
    dougbryson
    I currently use Pinnacle's Studio DV capture card and software. It only costs £80 and is a piece of cake to use. Results are great - you can add music easily from CD and if you upgrade the software for about £50 from Pinnacle you can get loads of extra great features to give very good results for very little money. Highly recommended.
    Doug.
  7. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    Doug,<br />I thought the Studio DV was about £170. Can you point me in the right direction for retailers selling at £80?
    Regards
  8. sraper
    sraper
    Aug 7, 2001
    825
    Watford, UK
    +268
    Chris,
    I believe their are two packages out there. Studio DV for about £80 and Studio DVplus for about £170. The only difference is that the more expensive one allows analogue (s-video) output. Checkout <a href="http://www.pinnaclesys.de/uk/" target="_blank">Pinnacle</a>. Seems rather alot more for the s-video out! I was planning on going this route but found out that Studio does not support widescreen. In the end I ordered a Adaptec card which comes with MGI VideoWave for about £60. Can't tell you how good it is as it hasn't arrived yet.
