Which Dual DVI card?
Discussion in 'Desktop & Laptop Computers Forum' started by dan1979, Oct 27, 2004.
  1. dan1979
    dan1979
    Sep 16, 2004
    3,525
    83
    +201
    My TFT has a horrible pic via VGA so I want to connect that and my projector both via DVI.
    I've seen a few cards like a Matrox one for £105 and an Asus 5200 for £65
    I don't intend on playing any games, just internet browsing and watching dvd's/streaming media through it so can anyone suggest the best option, as cheap as possible.
    Current card is an XFX Geforce Ti4200 which currently works fine for my needs.
  2. Alain75
    Alain75
  3. dan1979
    dan1979
    Sep 16, 2004
    3,525
    83
    +201
    There's a few around but they seem quite pricey, I've heard the 5200 is quite poor. Worse than the Ti4200 I already have but as I'm not playing any 3D games it shouldn't make a difference.
  4. Alain75
    Alain75
    Yes I'm not playing games either, but according to the AVSforum the 6600 is one if not the best card currently for HTPC, (especially for HD) due to the on board video processor and wmh support.
  5. mephistopheles
    mephistopheles
    You could always use a DVI splitter. They're not cheap but it would open out the possibilities for you.
  6. Alain75
    Alain75
    Yes but I guess the idea is to create a true dual screen environment, ie a movie/tv channel on the projector/rptv/plasma, and web browsing/messing around on the TFT next to the couch, with the PC as the common source, so the splitter wouldn't do the job, at least for me ! ;)
  7. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    From a brief encounter with an nVidia card, after a long time with ATIs, the nVidia dual-monitor support seems easier to use and the 'theatre' mode at first glance looks ideal.
