Which dish for sky+
Discussion in 'Sky Digital TV Forum' started by Doctor_AB, Jan 9, 2004.
  1. Doctor_AB
    Doctor_AB
    Aug 30, 2003
    2,445
    48
    Buckinghamshire
    +79
    Currently have 2 sky dishes. Had one for sky and when had a mirror sub, sky installed new dish for 2nd box. Having sky+ installed on 31st Jan. What should I do with dishes? Keep one or both. If one which one? Does the larger dish give a better reception as it seems to do at present. Can a quad LNB be installed on a larger dish or is it only for mini dishes. Live in quite a hilly area although reception is good.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    sky should be able to Fit LNB to a mini dish and it should give a better feed for poor weather etc as long as it is properly aligned. If larger dish feeds room where sky+ is to be installed thats probably what they will do any way.
  3. wod
    wod
    Sep 7, 2003
    196
    +3
    yes keep the bigger dish and get them to install the quad lnb on it
