Sapper Pete
- Joined
- Jul 5, 2005
- Messages
- 19
- Reaction score
- 0
- Points
- 13
I have been given a Goodmans GDVD 305 recorder with Freeview.Being new to DVD I would appreciate advice on the following.
With my existing VCR,I can make a recording,remove the tape and then follow up with further recordings at a later date up to the level of 3 or 4 hours.Later,I can rewind the tape and use it again.
Given the range of discs available,which one should I use to replicate the foregoing ?
