Which disc for 'Starters'
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dennis Leighton, Dec 28, 2004.
  1. Dennis Leighton
    Dennis Leighton
    Apr 19, 2003
    381
    28
    Priorslee,Telford, Shropshire
    +55
    My new JVC DR-MV1 will be delivered in the next day or two. I am anxious to transfer about 80 VHS tapes to disc - each being 3 hours in length - so that they can be archived. Which disc format is the best for this purpose and will a 3 hour tape go onto one disc? I'd very much appreciate some help.
    Many thanks.
  2. CHR1S
    CHR1S
    Depending on what quality you are wanting, I have archived all of my VHS tapes in XP mode which gives you 1hour per 4.6GB DVD, mine were irriplacable home movies which I wanted to copy without loosing any quality. I would personally experiment with DVD-RW or +RW before you create 'coasters' with non erasable -R / +R media.
    Chris
  3. applevenus
    applevenus
    I've found the compatibility guides when buying blanks from svp.co.uk to be pretty useful. You can also order sample packs from there which might help.
  4. johnjackthom
    johnjackthom
    Sep 20, 2001
    748
    Northumberland
    +283
    Yes, experiment with DVD-RWs to become accustomed to the machine and the recording quality options. Don't even think of archiving on -RW though as they are generally not as robust as DVD-R.
    Personally I find 2 hours per DVD to give very good results but would certainly not risk going beyond that figure.
  5. Dennis Leighton
    Dennis Leighton
    Apr 19, 2003
    381
    28
    +55
    Thank you All for your speedy and knowledgeable replies. They have helped enormously.
