I live just outside Slough (well, somone has to ;-) and I've been told by a couple of fairly local CAI approved installers that the digital signals where I live should be pretty good.
I'm proably going to replace the aerial on the chimney stack, but how can I choose which one to replace it with, I'd like to avoid paying £70 or more just for labour to have one fitted.
ordering from CPC www.cpc.co.uk , part number - AP00833 for example.
I was thinking of getting a wideband unit to make sure I get the most versatility.
Does the state of the mast make a difference?
Would a high gain be a better bet than a medium gain, will it make much difference as I seem to recall that too much gain on analogue can be just as bad as too little.
Also, will all digital aerials be compatible with analogue signals as we still have analogue on the main TV.
Skiddins
Skiddins
