Which Digibox receiver?????
Discussion in 'Satellite TV, Sky TV & FreeSat' started by nobby, Aug 19, 2002.
  1. nobby
    nobby
    Dec 28, 2001
    622
    46
    wee Norn Iron
    +143
    :confused:
    Hi guys
    i was wondering what digibox would be the best for my needs
    i am installin a projector and have got an s-video cable installed into the walls and ceiling. i am hopin to use this connection for sky as i have component leads for the dvd player.
    can someone let me know which box will cover my needs. i was told if i get the grundig box as part of the install would be ok.
    your thoughts please, or do i have to upgrade and what would the costs be?
    thanx in advance
  2. Guest
    Only one (vanilla) Sky box has s-video out, AFAICR. Is that the Grundig ? Sky+ boxen have s out though.
    HTH,
    Mike.
  3. wvoss
    wvoss
    The Grundig GDS3000 has S-Video Out. Not much of a chance of getting this box from Sky on Installation.
    Nearly bought one on E-Bay for around £130. Take a look.
    Ended up with the Sony-760U with Optical out.
    Suppose I'll buy a convertor or a scart(RGB) to S-Video cable. Not sure which is best? Anyone?????
  4. Guest
    "scart(RGB) to S-Video cable" ???? Cannot be wired so doesn't exist, AFAIK. You need a convertor.
    You can get composite to S convertors for under a tenner, BTW.
    Mike.
  5. Kevo
    Kevo
    Aug 23, 2001
    5,448
    Manchester
    +166
    Better still, get an 'RGB to S-Video' Converter from www.rgbtosvideo.co.uk
    Cost a bit more than a tenner though!
    I use one from my NTL STB to record onto SVHS, and they are worth every penny, excellent quality over SCART composite to SVHS.
  6. Caveat
    Caveat
    Ive got a Panasonic box with RCG and it pumps SVideo out to the TV just fine.
    I would STRONGLY recommend using a PC or Scaler and feeding progressive to the projector rather than SVideo though.
    I use a DTTV box into a PC (£35 Hauppage card and DScaler) and the results are excellent on a 1.8m wide 16x9 screen
