Which DF Sub +Sats combo??
Discussion in 'Subwoofers' started by Pebble, Sep 12, 2005.
  1. Pebble
    Pebble
    Nov 18, 2003
    311
    Grangemouth
    +4
    Hi all, :hiya:
    I'm looking for a small/compact DOWNWARD firing sub + small stylish sats to comply with the new WIFE regulations for 2005. :lesson:
    Budget would be approx £1k
    I will be placing the sats on the wall , so they should be quite discrete.
    I like the look of the M-cube + B/W M-1 as sats and as DF subs go the one that takes my fancy is the BK XLS2000-DF
    Would any of these combo's be any good for movies + music??
    I have a Pio D2011 as the amp
    Cheers :smashin:
    Pebble
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    What would make the sats stylish?
    I can't stand metal or silver speakers. :blush:
  3. binbag
    binbag
    Jun 16, 2004
    1,694
    +81
    It does matter what the speakers look like; she'll still complain about the wires. :nono:
  4. Pebble
    Pebble
    Nov 18, 2003
    311
    Grangemouth
    +4
    Anyone??
    And would the BK 2000XLS-DF be a better bet for sound quality than the B&W (maybe not the PV1) + Mission subs that usually come as a package with the sats
    pebble
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Well I think that the BK sub would be an excellent choice but really don't know much about the kind of speakers you're interested in I'm afraid. B&W do seem to be making some good stuff at the moment though and I wasn't impressed by the comparable Kef range. :)
  6. SBanga
    SBanga
    Mar 23, 2005
    2,011
    Leeds, Yorksha
    +267
    Not many subs will match the Mission M-Cubes sats, as they only reach down to 280Hz, so the Mission sub is designed specifically for these speakers. However, the sound is still excellent for a sub/sat system, as long as you don't put the sub anywhere but between or next to the front two. Anywhere else and you will hear where some of the midrange is coming from. If you see this being a problem, stick with the B&W set as they reach down to 80Hz and they will better suit a sub upgrade.
