which denon receiver? 2802 or 3802
Discussion in 'AV Receivers & Amplifiers' started by shoestring25, Feb 2, 2003.
Tags:
  1. shoestring25
    shoestring25
    Feb 2, 2003
    3,332
    essex
    +207
    i don't know which one to get the 3802 has DDSC digital and 7x 105w while the 2802 has 6x90. that apears to be the only differnces, and of couse price. i have not got the room to add a sixth speaker for EX or ES so the 6 or 7 channel is a non factor. any advice will be very gretfully received.
    speakers will be infinity alpha 40s/10s/center and relQ150
    cheers:D
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    These receivers have been superceded by the 2803 and 3803 now. Buy the one that you prefer the sound of and can afford, can't give any other advice really. They both offer pretty much similar specs, up to you.
