Which Da-Lite Screen for my AE700? Please help...
Discussion in 'Projectors, Screens & Video Processors' started by soulkisser, Jul 23, 2005.
  1. soulkisser
    soulkisser
    Hi.
    I'm going to buy a new screen for my AE700, (which rocks by the way). What gain should I be using? And which surface?? :rolleyes:
    Thanks.
  2. soulkisser
    soulkisser
    By the way, I found the following, is it any good?
    High Contrast Cinema Vision
    Designed for today's moderate output DLP and LCD projectors, this screen surface is a great choice when video images are the main source of information being projected and where ambient lighting is moderately controlled. With its specially designed gray base surface and a reflective top surface, this screen material is able to provide very good black levels and brilliant white levels. This screen surface provides deep life-like colors and greater detail and sharpness to the image.
    Gain: 1.1 Viewing Angle: 45°
