Which CRT Tv for Gaming ( Component )
Discussion in 'General TV Discussions Forum' started by BIONIC MAN, Nov 21, 2003.
  1. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    I'm looking for a widescreen Tv for Gaming Only :p
    Must have the following connection's
    32inch Widescreen
    Component input & rear Audio input for Component
    1 or 2 RGB Scart inputs
    100 hz for 60 hz games
    So what's the best all rounder for the above :smashin:
    :devil:
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,282
    United Kingdom
    +1,564
    Have a look at the JVC HV32D25, can be got for around 850 quid if you shop about. Has 3 scarts (2 x RGB), Component Inputs (accepts both PAL and NTSC progressive) and a 5th AV Input (S-Video & Composite). It also has both Optical and Coaxial digital inputs and analogue audio inputs. NTSC is set at 60hz but PAL is upped to 75Hz on this TV (unless it's a Progressive signal). The Super Digipure circuit increases resolution to 1250i for PAL and 1500i for NTSC and for gaming looks superb. :)
  3. Magsy
    Magsy
    Oct 18, 2002
    107
    I'm a bit behind the times with CRT tellys, Im a PJ user so I just have a cheap 28 widescreen.
    But, do these tellys now offer, true progressive display? Ie like a pc monitor ?
    What resolution do they claim it at?
