Which crt tv for £500ish?
Discussion in 'General TV Discussions Forum' started by Bren, Jul 28, 2005.
  1. Bren
    Bren
    Jan 23, 2004
    1,688
    48
    +67
    Looking to buy a crt widescreen tv with dolby pro logic & dont want to spend over £500 so whats the best?
  2. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    Are you sure you want Prologic? Not many TVs have it these days and none that I can think of below £500. I'd strongly recommend buying a basic but well designed TV such as this http://www.comet.co.uk/comet/html/cache/453_210064.html for about £300 and spend the rest of your budget on an entry-level AV system that you can connect to your TV. (Pricerunner is a pretty good starting point for both)
