Which CRT should I buy?
Discussion in 'General TV Discussions Forum' started by dungarth, Dec 27, 2004.
  1. dungarth
    dungarth
    Decided it's time to get a new TV as the old Tosh is getting dated. I am looking for a 32inch CRT. The most I am prepared to spend is £800. Just wondered if you guys could advise me on which TV's are worth looking at?
  2. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    If you are used to 100htz tvs have look at the tosh 32zp48.Very good set with quality picture and sound.If you are not sure about 100htz processing try and get a demo.
  3. anna the dub
    anna the dub
    Dec 14, 2004
    274
    +12
    I have a JVC hv32d40. More than happy with this 75Hz telly, and it has Pal Progressive and a freeview tuner. Got mine for slightly over £700
  4. red16v
    red16v
    Aug 20, 2004
    552
    +5
    I thoroughly recommend the Toshiba 32ZP48. regards, yt.
  5. Solwood
    Solwood
