which connection is the best
okey
I have just brought a new motherboard asus m2npv-pm
and it has the following connection on it,
vga out
dvi-d out
Y, Pb, Pr
I have a philips 32"lcd with hdmi socket on it, and y, pb, pr inputs
is component the same has hdmi without the audio?
MarkSS
dvi-hdmi would be best but with PC to LCD its more often a case of which connection will give you the correct resolution i.e. the native resolution of the screen.
T0rNaDo
dvi is the same as hdmi. without audio
component is the best analog video signal...
dvi is digital video.
hdmi is digital video and digital sound
if im right.....
kolabere
Use in this order for preference: VGA; Component and DVI-D (least - best).
Just to confuse a little DVI can be digital, analogue or integrated :eek: . All About DVI should help.
DVI-D does use the same video protocol as HDMI.
I agree, but to be pedantic the correct resolution is the one which works best for your setup, this may not be the native resolution.
e.g. I have a Sony XL100 connected to a Toshiba 32WLT66 with HDMI-HDMI @1216 x 684, far from the native res of 1366 x 768.
PeteD64
Why do you say VGA is worse than component? Lots of us use VGA to connect to our screens because it gives the clearest image.
mark.carline
The best one ??
Easy...
Try all of them and pick the one *YOU* are most happy with.
That will then be the best one - :lesson: - Dont just pick the best one based on teckky stuff
Theres too many variables to think about, quality of card, cable, tv etc etc etc
kolabere
Please read carefully (emphasis added)
and
. . . the correct resolution is the one which works best for your setup, this may not be the native resolution.
Mark states it far more practically - I'm much more a theoritician :D .
MarkSS
Go on then, I'll bite. Why on earth is that the best resolution for your setup and why is that better than having 1:1 mapping?
jameson_uk
You will find that different combinations of graphics cards, TVs and connections will give you different sets of available resolutions and different results. (eg I did try via componennt at one point and got overscan)
For MCE and the like you will not notice any difference but if you are using the windows desktop 1:1 pixel mapping is very noticeable.
kolabere
It's the best for me because it works better than any others I've tried (Using the "Mark Carline Method") - Windows/Internet browsing from about 2m is excellent, so is MCE . . . the end :thumbsup: .
Similar threads
