Which composite cable? RCA or BNC??
Discussion in 'Cables & Switches' started by gan*, Jan 30, 2004.
  1. gan*
    gan*
    Oct 18, 2003
    77
    Im getting a Toshiba 42WH36 and a Sony NS730 DVD. I want to make use of the prog scan, so what connectors do I need to order? RCA or BNC?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    RCA and BNC are the termination types so what ever the DVD and TV are fitted with, (this is nothing to do with composite by the way)
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    For component (for prog scan) you will need 3 75ohm cables normally RCA but check your equipment and manuals to be sure.
  4. gan*
    gan*
    Oct 18, 2003
    77
    cheers, anyone know what the toshiba and sony use, because i want to get the cable before tv arrives.
  5. Jason S
    Jason S
    Most probably RCA, although you may be able to find the manuals on the manufacturers website and confirm it.
    You can also easily pick up RCA - BNC adapters from maplin. I used these on my plasma for a while until getting custom made cables.
  6. shauney_r
    shauney_r
    The Toshiba end is definately RCA. Sorry but can't help with the Sony.
