Which component cable?
Discussion in 'Cables & Switches' started by Bobdad, Oct 21, 2003.
  1. Bobdad
    Bobdad
    I need to buy some long component leads (10m) to connect my plasma to my dvd player, but I can't decide whether to go for something reasonable like Van Damme or whether to spend extra on the QED range.
    From what I've read it is debatable whether any difference is noticable.
    See:
    http://www.whatvideotv.com/testbench/Cables/QED/QEDQuinexP-CV+SR-CV.php
    However, the suggestion from this review however is that long lengths introduce interference, therefore justifying extra expense.
    Can anybody comment from experience?
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,675
    UK
    +115
    Have a chat with Joe at TMF (www.tmfsolutions..co.uk) he stocks the Van Damme cables amonst others...may be able to give you an honest view...
    HTH
    JJ
  3. alexs2
    alexs2
    Nov 13, 2002
    13,897
    +1,671
    The big problem with long cable runs is cost and screening...yes,good quality cables will give better results,and a cleaner signal in many cases,but with the sort of runs you're looking at,it can end up being very expensive.....I use Kimber DV30,but I honestly wouldn't recommend it for your application in terms of cost.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,310
    +1,217
    Profigold 10m component are pretty good and only £70-80 they are well screened and have ferrite cores at each end to minimise noise.
  5. Cambo
    Cambo
    Mar 10, 2002
    123
    N.Ireland U.K.
    Do a search for Mark Grant. He sell's great component cables and gets fantastic reviews from people like me who've bought off him.
  6. Epoman
    Epoman
    Jan 3, 2002
    3,082
    71
    On my PC
    +85
    I'm facing the same issue at the moment.
    Has anybody compared cheap and expensive cables?
  7. inzaman
    inzaman
    Dec 16, 2002
    7,955
    Derby
    +1,021
    Try here for excellent custom made cables at very good prices. A 20ft component cable, beldon cable and canare connectors, cost me about £75. This thing is as thick as a hose pipe it has that much shielding etc.
  8. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,441
    7
    167
    Birmingham, UK
    +10,144
    They are in the states, though.
    Check out our Power Buys.
  9. darren7
    darren7
    van damme, top stuff for the cash.
    broadcast standard. around £50 for 10M
    Darren
  10. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,136
    Cumbria
    +1,276
    Power buys :)
  11. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +11
    BlueJeansCables seem great. I've just bought a Belden1694A with Canare terminations (5ft) for use as a Digital IC from them and it cane to about £10 with shipping!
    The Canare cables are very good also.
  12. TwistedPear
    TwistedPear
    Sep 14, 2003
    20
    Stratford upon Avon
    Hi, would you consider an alternative approach.
    I run www.MadNat.com (an AV Forum sponsor), and we sell Audio and Video Baluns.
    These plug and play devices let you run audio and/or video signal over cheap and easy to hide Cat5 twisted pair.
    Another advantage of Baluns is the ability to make very long runs with little signal loss.
    There is a Component Video product (500021), which would provide a solution for your requirement.
    I hope this is helpful.
  13. Paul Williams
    Paul Williams
    Jul 4, 2003
    812
    Plymouth/Devon
    +16
    My vote also goes to Blue Jeans; even with shipping, PayPal set-up and duty+postie admin the cables I bought were cheaper (by some margin) than any UK direct equivalent.
    Paul
  14. Legin76
    Legin76
    Aug 10, 2003
    58
    The Profigold cables that hornydragon mentioned can be got for £50 from here
    Just noticed this is an old thread :blush:
