Which chose of cheap amplifier to beef up sound on LCD TV
Discussion in 'Hi-Fi Stereo Systems & Separates' started by toshinator, Dec 31, 2006.
  1. toshinator
    toshinator
    Hi...1st time poster so apologies if I've posted in the wrong place. I bought a 15" LCD TV for the kitchen but the sound is very tinny. I want to use the audio output of the sky box that is connected to this tv to amplify sound and wondered if anyone could recommend a cheap amplifier and speakers to do this job. Appreciate any comments. Thanks.
  2. toshinator
    toshinator
    Anyone?...or at least where I should be posting this?
  3. Dan.Scott1234
    Dan.Scott1234
    Nov 17, 2005
    1,321
    41
    Wargrave
    +18
    one idea could be a monitor audio i-deck, they're on sale at about £100 at the moment and have a line in for your LCD. Also you can put your ipod in there. Not exactly going to set the world on fire but a lot of bang for the buck!
    Dan
  4. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    little active speakers ? - no amp then, ah don't know if you can control volume on your sky box though.
  5. Dan.Scott1234
    Dan.Scott1234
    Nov 17, 2005
    1,321
    41
    Wargrave
    +18
    its for a kitchen I could say a naim pre/power solution would make sky sound fantastic on the 15"LCD but it would be overkill, as would an amp in the kitchen when a small set of active speakers would probably be enough.
    Alternativly any set of PC speakers would also be fine creative labs do some 2.1 setups that start from about £30 that will also be fine
  6. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    How about a Sonic Impact T amp (ebay £31) and some JBL Control 1s (Richer sounds £50)?
  7. pdiddy
    pdiddy
    Dec 7, 2004
    390
    +38
